Skip to content
Loess from scratch in Python + Animation
Introduction
Loess is a class of regression models that allows us to estimate the regression function \(f(X)\) by fitting a simple (and different) model to each point in the domain \(X\). This is done by paying attention to the points closest to a particular target point \(x_0 \in X\).
In the classic simple linear regression we have the following model:
\[ y_i = f(x_i) + \epsilon_i\]
where \(f(x_i)\) is:
\[f(x_i) = \beta_0 + \beta_1 \cdot x_i\] and in the case of loess with approximate \(f(x_i)\) by a polynomial weigthed by a function \(w_i\) that assigns higher weights to points \(x_i\) that are closer to \(x_0\):
\[f(x_i) = w_i(x_0) \cdot [\beta_0 + \beta_1 \cdot x_i + \beta_2 \cdot x_i^2 + \dots]\]
Procedure:
  1. Let \(x_i\) denote a set of \(n\) values for a particular variable and let \(y_i\) represent the corresponding response variable.
  2. Find the \(k\) closest points to the target point \(x_0\). Let’s denote this set \(D_0\)
    • For implementation, keep track of these points and their distances \(d_{i0}\)
  3. Find the furthest distance among those \(k\) points. Let’s denote this quantity as \(\delta(x_0)\)
  4. Calculate the weight function \(w_i\) for each \(x_i \in D_0\) using the tricube weight function:
\[w_i(x_0) = W(\frac{d_{i0}}{\delta(x_0)})\]
where \(W(\cdot)\):
\[\begin{equation} W(u) = \begin{cases} (1 - u^3)^3, & 0 \leq u < 1 \\ 0, & \text{otherwise} \end{cases} \end{equation}\]
  1. Calculate the prediction \(\hat f(x_0)\) by solving weigthed least squares. The normal equation can be expressed as followed:
\[\begin{align} WX\hat \beta &= Wy \\ X'WX\hat \beta &= X'Wy \\ \hat \beta &= (X'WX)^{-1}X'Wy \end{align}\]
  • You need to use only the \(k\) closest points for each target point \(x_0\)
    • In the case of a polynomial of degree 1:
      • W is a 2x2 diagonal matrix
      • X is a kx2 matrix (column 1 it is a column of 1’s for the intercept)
      • y is a kx1 vector
    • In the case of a polynomial of degree 2:
      • W is a 3x3 diagonal matrix
      • X is a kx3 matrix
      • y is a kx1 vector
  • With the estimates of \(\hat \beta\) you can calculate \(\hat f(x_0)\)
Implementation
In the implementation, I included an option to not use all the \(x_i\) points as \(x_0\) because when there are many samples, the fit takes long time.
Also, to solve the normal equation above, I did a QR decomposition for stability 1.
import numpy as np
import pandas as pd
import matplotlib.pyplot as plt
import seaborn as sns
from scipy.linalg import qr, pinv
from scipy.linalg import solve_triangular
def loess(X, y, alpha, deg, all_x = True, num_points = 100):
    Parameters
    X : numpy array 1D
        Explanatory variable.
    y : numpy array 1D
        Response varible.
    alpha : double
        Proportion of the samples to include in local regression.
    deg : int
        Degree of the polynomial to fit. Option 1 or 2 only.
    all_x : boolean, optional
        Include all x points as target. The default is True.
    num_points : int, optional
        Number of points to include if all_x is false. The default is 100.
    Returns
    y_hat : numpy array 1D
        Y estimations at each focal point.
    x_space : numpy array 1D
        X range used to calculate each estimation of y.
    assert (deg == 1) or (deg == 2), "Deg has to be 1 or 2"
    assert (alpha > 0) and (alpha <=1), "Alpha has to be between 0 and 1"
    assert len(X) == len(y), "Length of X and y are different"
    if all_x:
        X_domain = X
    else:
        minX = min(X)
        maxX = max(X)
        X_domain = np.linspace(start=minX, stop=maxX, num=num_points)
    n = len(X)
    span = int(np.ceil(alpha * n))
    #y_hat = np.zeros(n)
    #x_space = np.zeros_like(X)
    y_hat = np.zeros(len(X_domain))
    x_space = np.zeros_like(X_domain)
    for i, val in enumerate(X_domain):
    #for i, val in enumerate(X):
        distance = abs(X - val)
        sorted_dist = np.sort(distance)
        ind = np.argsort(distance)
        Nx = X[ind[:span]]
        Ny = y[ind[:span]]
        delx0 = sorted_dist[span-1]
        u = distance[ind[:span]] / delx0
        w = (1 - u**3)**3
        W = np.diag(w)
        A = np.vander(Nx, N=1+deg)
        V = np.matmul(np.matmul(A.T, W), A)
        Y = np.matmul(np.matmul(A.T, W), Ny)
        Q, R = qr(V)
        p = solve_triangular(R, np.matmul(Q.T, Y))
        #p = np.matmul(pinv(R), np.matmul(Q.T, Y))
        #p = np.matmul(pinv(V), Y)
        y_hat[i] = np.polyval(p, val)
        x_space[i] = val
    return y_hat, x_space
To test the implementation and create the animation, I replicate the following lecture notes 2. The dataset is located here 3.
import matplotlib.animation as animation
from matplotlib.animation import FuncAnimation, PillowWriter
c4 = pd.read_csv("cd4.data.txt", delim_whitespace=True, header=None)
y_hat2, x_space2 = loess(c4[0], c4[1], 0.05, 1, all_x = True, num_points = 200)
d = {'x': x_space2, 'y': y_hat2}
c4_pred = pd.DataFrame(data = d)
c4_pred = c4_pred.sort_values(by = ['x'])
c4_pred = c4_pred.reset_index(drop=True)
def animate(i):
    x_data = c4_pred.x.values[:i]
    y_data = c4_pred.y.values[:i]
    #sns.scatterplot(c4[0], c4[1], color ='skyblue')
    sns.lineplot(x= x_data, y=y_data, color = '#EE6666')
fig = plt.figure()
plt.ylim(1, 1550)
plt.xlabel("Time since zeroconversion")
plt.ylabel("CD4")
plt.title("CD4 cell count since zeroconversion for HIV infected men")
writer = animation.PillowWriter()
ani = FuncAnimation(fig, animate, frames = np.arange(0, 2376, 40))
ani.save('ani_cd4.gif', writer=writer)
